a motor on a tubed chassi cant really be compared to a full road car, stick that motor in somthing of a similar weight and just laugh at how much it sucks.
still pretty cool tho, racing from a roll, lol
i'd hardly call this "mind blowing"... just look at the power to weight ratio. I'd rather a full bodied car with all the luxury trims and still be damn quick.. than that kit car with "free" air conditioning :)
another aussie tryin to make a buck in america... tsk tsk
another KIWI inventing something amazing in the motor world... much like the guy who invented the jet boat and Mr. Britten who made a motorbike in his shed which was years ahead of its time.
the power to weight ratio isnt that much better then a Ferrari or the Porka and as stated its based on the Atom which is a road legal car.
the batteries in this version weigh over 250kgs alone from memory... id definately have one as a nice weekend track toy.
Power to weight advantage where????
Porka GT = 605BHP and 3000lbs
Aerial X1 = 300Bhp and 1500lbs
wheres the advantage? its at a disadvantage by my calculations as it has less then half the power but half the weight
dont like the way they compare it to full size cars, y not compare it to a Hayabusa or R1?
probably cause its not a motorbike?
so if they invented a mini that ran 10s from factory they shouldnt compare it to s super saloon?
its merely to show what you can achieve using alternate fuels. A point that seems to escape most people. The car is ELECTRIC. Performance electric cars are few and far between unless you count that ugly 600kw 6 wheeled japanese thing.
Exactly what inark said, the point of the clip was to examine the potential of alternative powers sources other than fossil fuels. One day there wont be any petrol to burn and we'll all prob be driving these 11 sec things. Another thing to consider is the price of petrol versus plugging your car in the wall for a few hours. As time goes on and technology progresses the weight on the batteries will come down aswell as provide more power.
Also there is no advantage, the power to weight is about the same anyway, WTF are you guys on??
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
