a motor on a tubed chassi cant really be compared to a full road car, stick that motor in somthing of a similar weight and just laugh at how much it sucks.
still pretty cool tho, racing from a roll, lol
i'd hardly call this "mind blowing"... just look at the power to weight ratio. I'd rather a full bodied car with all the luxury trims and still be damn quick.. than that kit car with "free" air conditioning :)
another aussie tryin to make a buck in america... tsk tsk
another KIWI inventing something amazing in the motor world... much like the guy who invented the jet boat and Mr. Britten who made a motorbike in his shed which was years ahead of its time.
the power to weight ratio isnt that much better then a Ferrari or the Porka and as stated its based on the Atom which is a road legal car.
the batteries in this version weigh over 250kgs alone from memory... id definately have one as a nice weekend track toy.
Power to weight advantage where????
Porka GT = 605BHP and 3000lbs
Aerial X1 = 300Bhp and 1500lbs
wheres the advantage? its at a disadvantage by my calculations as it has less then half the power but half the weight
dont like the way they compare it to full size cars, y not compare it to a Hayabusa or R1?
probably cause its not a motorbike?
so if they invented a mini that ran 10s from factory they shouldnt compare it to s super saloon?
its merely to show what you can achieve using alternate fuels. A point that seems to escape most people. The car is ELECTRIC. Performance electric cars are few and far between unless you count that ugly 600kw 6 wheeled japanese thing.
Exactly what inark said, the point of the clip was to examine the potential of alternative powers sources other than fossil fuels. One day there wont be any petrol to burn and we'll all prob be driving these 11 sec things. Another thing to consider is the price of petrol versus plugging your car in the wall for a few hours. As time goes on and technology progresses the weight on the batteries will come down aswell as provide more power.
Also there is no advantage, the power to weight is about the same anyway, WTF are you guys on??
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
