Everyone goes too soft in the rear on Skylines for the drags and it is DUMB!
Hands up who wants 1/4 of their rear tyres on the tarmac???
Didn't think so.
My rear suspension is hard as buggery :D
Only if the suspension and camber is setup incorrectly to start off with.
Stock like soft on the rear is good.
Didn't think so.
My rear suspension is hard as buggery :)
Most people agree that a softer rear end assists squat and weight transfer
But the problem with R32/33/34's is excessive camber change on squat.
So to avoid camber change you use hard springs
But that's band aid (covering up the real problem)
Why don't you eliminate the camber change?
Then you can take advantage of the squat, weight transfer.
Forget I told you that, just keep on doing what you are doing, you are already going fast enough.
:) cheers :P
Edited by Sydneykid
drag Suspension is ment to go down fast but come up slow, HKS Suspension has mastered this
It's not difficult, just select the appropriate bump and rebound valving.
There is no magic.
I have done quite a few cars using Bilsteins, for less than 1/3 what HKS charges
:( cheers :D
you need the rear to squat a little and the front to push up to asist this weight transfer, but after the launch you need the rear suspension to seperate, pushing the tyres down into the track, this is the trick, especially with IRS cars that want to squat and stay squating. Spring rate and shock adjustment is critical and may take a few test and tune days to get working well.
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
