I need to change my wheel studs to 10mm longer ones....
Will I need a bit of experience in changing them. Admittedly the front seems a tad easier than the rear, is this correct?
Will I be needing any special tools?
Any advice would be appreciated, and if it has been spoken about before a link would be good as my searches for this have not been successful...
https://www.sau.com.au/forums/topic/119578-how-to-remove-wheel-studs/
on the back of the hub there is a guard, there is a hole which lines up with the stud as you rotate the hub. line it up, and tap it out with a hammer, from the wheel side of the hub inward. then to replace, do the opposite... easy
