:) Hi everybody,
My name is Rik. I have read the SAU forums for a lot of years but have never posted. I am a Skyline enthusiast. :D Regrettably, I am selling my Skyline – I have been meaning to sell it since December but it is too hard to let go. I need a ute for work. I figure, might as well pass the car from one enthusiast to another!
I am new at this, so let me know if there are any details or photos you want in particular. I am having trouble attaching photos, so hopefully I will figure that out soon! In the meantime if you want any photos let me know and I can email them to you at a reduced file size.
Contact me anytime on 0421619811, or reply to this post :D
I'll skip listing all the standard features of this model, as you probably already know them! Here is a run down of my car. The car has clocked 92,000km. I purchased it with 69,000km on it in 2002. I have a 2nd car so the Skyline sits in the garage most of the time.
ENGINE
-212KW at rear wheels @ 10PSI
-Blitz front mount intercooler
-HKS air filter
-Unichip programmable ECU (including electronic boost control)
-Malpassi rising rate fuel regulator
-Bosch motorsport fuel pump
-Full 3” stainless steel exhaust including CES dump pipe & Genie stainless rear muffler
-Exedy sports organic clutch 2800 pound clamping pressure
-HKS turbo timer
-Power steering oil cooler
SUSPENSION
-Bilstein shock absorber struts (front & rear)
-King Springs 50mm lowered springs (progressive rate)
-Whiteline front strut brace
-Whiteline front sway bar
-Whiteline rear sway bar
-Whiteline front adjustable camber,castor & toe bushes
-Whiteline rear adjustable camber,castor & toe bushes
INTERIOR
-Nismo 300km instrument cluster
-Pioneer 10 CD stacker (in boot) with in dash controller (+radio tuner)
-Infinity 150W RMS front split speakers with electronic adjustable cross over
-Kenwood 120W+120W RMS amplifier
-Darkest legal tint by The Auto Tint Shop
-Original Nissan floor mats
I purchase this vehicle in 2002. When I modified this car it was with 4 things in mind:
1.To comply with Queensland Transport
2.To comply with fully comprehensive insurance requirements
3.To retain original look
4.To produce safe & reliable engine performance
As you can see, I take great pride in my skyline. I paid a bit extra to ensure I bought a mint condition vehicle with low kilometers. It had 69,000km when I purchased it. The skyline has never spent a night outside the garage, and is usually only driven on weekends because I have a second car. I polish the car regularly and the interior is in ‘as new’ condition.
The car has always been fully serviced since I purchased it, and regularly tuned by Bob Romano.
You may think that the car is over priced, but if you are looking for a mint condition vehicle with genuine low kilometers that has everything already done to it, then this is a good buy!
Edited by rikbrisbane
Sorry to go off topic for the sale, but those are some impressive rwkw's considering the mods and only 10psi boost...:?
Do you have dyno sheets for this?
I need a good tuner to have a crack at my line to see if we can better the current power...
Back to the sale... :O
Edited by skyquez
Back to the sale... :sweat:
G'day! Yeah, the figure is genuine - I have plenty of dyno sheets as I progressively added on bits. I could go for more power, but at 10PSI you are not stressing anything - better to stay safe. The tuner is Bob Romano. Cheers! :)
G'day all :D
I have dropped the price to $20,000 ONO. Not sure what the market value is - I'm basing it on mileage, condition & features. I forgot to mention that it has clocked 92,000km. I purchased it with 69,000km in 2002. I have had a 2nd car to drive until a few months ago, so that is why the k's are so low.
Make an offer!
Cheers :laugh:
G'day,
The first person to actually come and have a look walked around the car once a put down a deposit. Unfortunately he couldn't get insurance. Come and see - it is truly mint condition.
Cheers :huh:
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
