trent_tr5 Posted May 26, 2006 Share Posted May 26, 2006 hey guys/gals, i have a 33 gtst with 3" catback and pod filter thats about it. now im looking to add more mods, wat would you suggest? im thinking an SAFC will i get much gain with these minimal mods? cheers, Trent Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/ Share on other sites More sharing options...
Wink Posted May 26, 2006 Share Posted May 26, 2006 Get a boost controller before SAFC2. SAFC2 won't help on a car running stock boost. Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2204879 Share on other sites More sharing options...
Quinny Posted May 26, 2006 Share Posted May 26, 2006 I am also looking at using either a SAFC or PFC. Is there really much benefit in going for the PFC for a mildly modified car? My mods will be exhaust, FMIC, 10psi, filter, thats pretty much it. Is it worth going for PFC, or would SAFC be ok. Sorry to hijack the thread, but it is kind of on the same topic. Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2204899 Share on other sites More sharing options...
Lithium Posted May 26, 2006 Share Posted May 26, 2006 i have a 33 gtst with 3" catback and pod filter thats about it.now im looking to add more mods, wat would you suggest? im thinking an SAFC will i get much gain with these minimal mods? Here is a dyno comparison from my R33 GTS25t with exhaust and intake. Only modifications between the two runs is getting rid of the factory dual stage boost control and putting in an R32 wastegate actuator, and tuning the car using an S-AFC2. Hope this helps Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2205457 Share on other sites More sharing options...
Munna1 Posted May 26, 2006 Share Posted May 26, 2006 Get a boost controller before SAFC2.SAFC2 won't help on a car running stock boost. Quinny a safc will help by triming the factory standard rich settings if you still wish to run standard boost. But it will make a bigger difference when you up the boost. Check out the site in my sig mate it should answer most of your questions and the tuning guides are written in the order id suggest to do your mods. Also do a search heaps of info on here too. cheers Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2205690 Share on other sites More sharing options...
Quinny Posted May 26, 2006 Share Posted May 26, 2006 Thanks Munna1, I have had a look at your tuning guides, and my mods are pretty much in line with the Stage 1 guide. I already have exhaust and pod, I will be getting a FMIC and boost controller soon. I will change boost to 10psi, other than that, I don't think I will be doing much more with the car because it starts to get into expensive mods after that. Around 180-200rwkw would be nice. I am just not sure whether it will be worth the extra $500 to get the PFC if the SAFC will do pretty much the same job. Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2205798 Share on other sites More sharing options...
mad082 Posted May 26, 2006 Share Posted May 26, 2006 i was in the same position you are, tossing up between safc and pfc. at low mods there is little bo be gained with the pfc, but should you every decide to up the boost, of upgrade the turbo then the pfc will suit much better. Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2205806 Share on other sites More sharing options...
The Mafia Posted May 26, 2006 Share Posted May 26, 2006 safc = waste of time I got a powerfc, fmic and exhaust and managed 210rwkw. Safc would be a dodgey 190rwkw or so Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2205860 Share on other sites More sharing options...
mad082 Posted May 26, 2006 Share Posted May 26, 2006 power gain would be dependant on how well the stock ecu is running. if it is running poorly then the power gain would be bigger, but if the stock computer is atually pulling its weight then power gain would be less. i got 204rkw with stock computer and turbo and my afr's were above average for a stock ecu, according to the dyno operator, so my power gain would be less than someone who's afr's were up the creek. as far as afr's go, performance gains between pfc and safc would be very little, it is just the fact that the pfc can control timing and other things that makes it a better unit. also if you have an auto then forget a pfc and just get a safc. Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2205875 Share on other sites More sharing options...
MKDR33 Posted May 27, 2006 Share Posted May 27, 2006 id recommend the SAFC II if you dont have enough cash to get a standalone ecu.. here is my last dyno printout when i had my SAFC2 tuned.. rb25det R33 HKS 2530kai turbo 3" Exhaust turbo back (custom twin pipe dump) Custom exhaust manifold Electronic boost controller FMIC SAFC II Blitz pod BOV Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2206329 Share on other sites More sharing options...
handyandy Posted May 27, 2006 Share Posted May 27, 2006 an safc2 with the sitc ( ignition timing control ) unit is great for people who dont want to do too much to their cars and is an inexpensive way to control your engine. Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2206340 Share on other sites More sharing options...
mickr33 Posted May 27, 2006 Share Posted May 27, 2006 Hey guys. I thought i'd give my parts a plug. Currently selling both a SAFC2 and Super ITC to control timing. Both are in excellent condition. Please check out the for sale section. Cheers Link to comment https://www.sau.com.au/forums/topic/119639-safc-gain-yes-i-searched/#findComment-2206685 Share on other sites More sharing options...
