Hi,
Im about to buy a R32 GTR, and am not sure about what type of turbo's it has.
The owner believes that they are N1's that were put in by the owner before him.
I checked the turbo housings and they had HKS written on them, i was under the impression that the N1's were made by Garrett. Can anyone shed more light on this?
Also, should an RB26DETT drop in revs when the oil cap is off, this didn't occur on the car i am considering to buy, should i be worried?
Thanks
https://www.sau.com.au/forums/topic/119665-r32-gtr-questions/
Hi,
Thanks
I think you will find that HKS are esentially the same as Garrett, i.e. they use the same components, they just have their own slightly different sizings, i have HKS turbo's on mine, but they are GT2530s, there should be an ID plate on them in the middle of the turbo (between the compressor and exhaust housing) that should tell you what they are...o and if you hear them spinning when u turn the car off for a little while then they are ball bearing :O
Hi,
Thanks
If they've got HKS on them they're obviously not N1's. Probably something like the GT-SS if they've got similar response the N1s.
I can't see why the revs would change with the oil cap on or off
Hi,
Thanks
HKS turbos are made by garrett as well, if they ahve HKS on them they are HKS not N1.
HKS GTSS are almost as responsive as stockers, 2530's are much bigger.
If it has a oil catch can and its vented it wont make any difference to the revs when you take the oil cap off.
If it doen't it should.
I think a compression test would be a more accurate and reliable measure.
Will definately do a compression test before I purchase the car.
Cool, thanks for that.
It doesn't have an oil catch can. :
Does the amount of rpm at idle effect the ability of the car to drop revs when the oil caps off? because this car was idling at 1250rpm.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
