Hi,
Im about to buy a R32 GTR, and am not sure about what type of turbo's it has.
The owner believes that they are N1's that were put in by the owner before him.
I checked the turbo housings and they had HKS written on them, i was under the impression that the N1's were made by Garrett. Can anyone shed more light on this?
Also, should an RB26DETT drop in revs when the oil cap is off, this didn't occur on the car i am considering to buy, should i be worried?
Thanks
https://www.sau.com.au/forums/topic/119665-r32-gtr-questions/
Hi,
Thanks
I think you will find that HKS are esentially the same as Garrett, i.e. they use the same components, they just have their own slightly different sizings, i have HKS turbo's on mine, but they are GT2530s, there should be an ID plate on them in the middle of the turbo (between the compressor and exhaust housing) that should tell you what they are...o and if you hear them spinning when u turn the car off for a little while then they are ball bearing :O
Hi,
Thanks
If they've got HKS on them they're obviously not N1's. Probably something like the GT-SS if they've got similar response the N1s.
I can't see why the revs would change with the oil cap on or off
Hi,
Thanks
HKS turbos are made by garrett as well, if they ahve HKS on them they are HKS not N1.
HKS GTSS are almost as responsive as stockers, 2530's are much bigger.
If it has a oil catch can and its vented it wont make any difference to the revs when you take the oil cap off.
If it doen't it should.
I think a compression test would be a more accurate and reliable measure.
Will definately do a compression test before I purchase the car.
Cool, thanks for that.
It doesn't have an oil catch can. :
Does the amount of rpm at idle effect the ability of the car to drop revs when the oil caps off? because this car was idling at 1250rpm.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
