Guys - here is a question that has rattled around my head for some time (be nice to me - newb)
what is the difference (in particular on a gtr) between rwkw and 4wkw. Is there much in it? If so is there generally a recognised formula to convert the two i.e. RWKW x 0.? = 4WKW.
Futhermore - once you have a KW at the wheels figure - is there a similar conversion to KW at the flywheel?
love to get some clarity on this subject - Thanks!
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/
umm not to sure what u mean by the rwkw to the awkw but the way i understand is rwkw is basically how mani kw ur puttin out at the rears where as awkw is wht ur puttin at all 4 wheels... usualy a awd drive train u loose about 40percent of the power or so i was told about WRXs so im guessin if u got a GTR ur loosin a bit of power through the awd system just by havin that draivetrain where as a rear wheel drive would only loose like 20 percent due to it only being rwd and much lighter....
sorry man i dont really know wht ur askin lol
but i gave it a go
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2205881
rwkw to flywheel kw is about 20% difference.
rwkw X 20% should give you flywheel KW.
Ive read its about 17-20% difference depending on the car but i think 20% is about right.
Unsure about 4wkw ?
im pretty sure Sydneykid stated a 60kw loss through skyline drivetrain in RWD .. so thats 80HP.
awkw to rwkw no idea lol
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2205908
HPI/ZOOM magazine did this with there silver R32 GTR running twin TD06'S. There tested the car on both a 4wd and rwd dyno, in both 4wd and rwd mode.
I think the difference was about 4% less with 4wd on a GTR.
Rwd to engine is about 80%. i:e your car makes 80kw at the rear wheels, its makeing about 100kw at the engine.
On something like a WRX thats full time 4wd its about 35%. So a STI with 206kw at the engine will make about 130kw-140kw at the wheels.
The GTR isnt fulltime 4wd, so the drivetrain losses arent the same as an Evo or Wrx.
Id say 20% loss from engine to wheels in rear wheel figures.
And 25% loss from engine to wheels in four wheel figures.
So if you have a 300KW @ THE ENGINE GTR,
In theory it would make 240KW at the rear wheels.
And 225KW at all four wheels....
Cheers.
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2205950
Before everyone gets way off the mark here..
Drive train losses remain static, they do not change, give or take a hp or two, due to better oils etc..
Don't follow the % rule, its wrong, and % losses calculated by coast down calcualtions are incorrect..
best way to explain this is like so, roughly a RWD car will loose about 25ish hp, as your only driving a couple of gears in the box, at 1 to 1 ratio, and the diff gears, so, if your car is making 200hp to begin with, you could say roughly, your making is 230 at the fly wheel, if you then mod the motor, but alter nothing in the driveline, and it now makes 400 at the wheels, its only going to make 430 at the fly wheel, not 460 for example if you where to use the % rule..
Automatic, and 4wd losses are higher, due to the nature in which they operate, but again the figures remain pretty constant, better oils, or driveline components alter this, but again the figure doesn't really move a heck of a lot, it remainds pretty constant, unless of course something is broken, and there is greater friction..
the 60kw figure quoted before im pretty sure is the loss you'll see from a gt-r in 4wd mode, as 60kw is a LOT of power loss for a manual RWD car..
also, a large portion of the driveline loss you see on rolling road dynos, is from the tyres, stuff like over/under inflation of the tyres, weight in the car, and tyre wrap around on the roller affect the figures, so if you dyno your car one day with the tyres at 36psi, then a week later they've gone down to 20psi, you will see less power, as the tyre is wraping around the roller more, more wrap, more friction, more friction the more power needed to over come it, so a lower reading will be seen, hub dynos eliminate this, which is why you will always see a slighly higher reading, and in some cases a bigger reading by comparision to a roller, as you eliminate wheel spin on the roller..
Edited by Denver
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2208090
slightly offtopic but when you dyno a GTR does it just drop straight to 50;50 split once it picks up the rears slipping heaps (or at least it thinks they are) or is more like a 30;70 split.
was that done with a torque split controller? or just lettting it go by itself?
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2208542
Their is just too many variables to figure with that question I think.
Manual trans - Auto trans
High stall converters - stock converters
Final drive ratios - drive train weight
Temperature - oil used
RPM
It goes on
:D
I like to think that what ever power you have on the ground, that you use all of it.
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2214151
not entirely answering your question but I have read that a GTR will never acheive a 50/50 split, even though it may show it on the guage, the front will always slip some compared to the rear.
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2236751
Not being an expert but having driven one on a number of occasions, GTR's distribute torque to the front wheels just by nailing it. Infact it doesn't have to floored or breaking traction. Any decent gforces even in a straight line will cause the guage to fly up to 50%. You can even be turning a corner with no throttle and it will start to distribute talk to the front which helps keep it stable.
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2236843
the guage is for KG/METRES OF TORQUE. not a percentage.
sooooo,. if you were to mesure the torque somehow at the front tailshaft with a torque wrench it could suply up to 50kg/m of torque before slipping.
its hard to explain. but its esentally a auto transmission that spends it life slipping. graduly feeding power to the front via a multi plate wet clutch
but. the power loss through 2wd/4wd. would be a good indication of how eficantly the transfercase is and how slippery the front dif oil is. also front wheel bearing drag.
so if anyone wants to do a back to back test with old diff oil and tranfercase oil.
then replace it all with new stuff and compare the differance id be interested at the results
https://www.sau.com.au/forums/topic/119673-rwkw-vs-4wkw/#findComment-2237034
    • Front wheeled vtec powered rb monster
    • Looking forward to the build thread!
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
