Ey i was wondering what 1/4 mile times you guys out there are getting and a breif low down on whats done to thecar?
The reason i ask is im takeing my car down to heathcote raceway tomorow with the cordia boys
and i wanted to c where abouts i sit in comparason
i've got a manual series 1 r33 rb25de
only mods atm are zorst clutch custom intake with poddie. cars getting weighed down a bit with a real nice body kit
Im in the process of turboing it and i have the intercooler all set up planning on running 1 or 2 runs with the intercooler running just to c what happens. i know there was at least one post about intercooling an n/a everyone says its not worth it n from the 10 mins of driving with it on i rekon i hasnt changed the cars power up or down but ey 1/4 mile trials will tell all of you out there that its prob not worth doing.
anywayz ill post up my times at the end of the day tommoz or mabye sun if i get home to late
https://www.sau.com.au/forums/topic/119678-14-mile-times/
Hey dude, with a big body kit and 17 inch "heavy" chromies back when it was a 2.5 NA i managed a best of 15.8 and 14.01 with a 75HP shot of gas, car had extractors, custom intake, 2.5" straight through exhaust and a home tuned SAFC, also had a big fiber glass body kit.
https://www.sau.com.au/forums/topic/119678-14-mile-times/#findComment-2205874
yo im back from the day out today can i say it was a mad day wiked turn out mostly old evo's and wrx's but all fun
I did my first two runs with the intercooler all piped up for anyone considering doing it DONT, i ran a 16.7 and 16.8
i did one amazing 14.15 which i think was an computer error
i ran two 15.5 runs @ about 88.92 mph
and i ran consistantntly 15.6-15.8
which i think is pretty good out of the n/a baby
Edited by unarmed_skyline
https://www.sau.com.au/forums/topic/119678-14-mile-times/#findComment-2206835
i just don't understand...
so you have read the post about intercooling an NA... but you did it anyway????
i mean, don't just look at it, READ IT
we were writing these things for a reason - its just not going to do ANYTHING
thats not true it made the car slower.
https://www.sau.com.au/forums/topic/119678-14-mile-times/#findComment-2210498
thankz na r33
waz i read all the stuff and i knew it wasnt going to help the car i just though i would confirm it. The reason i had the intercooler on is because im getting the car ready to turbo it, i didnt pay for piping or anything it was just a test which didnt cost me anything and was fun to try out
https://www.sau.com.au/forums/topic/119678-14-mile-times/#findComment-2211224
  • 4 weeks later...
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
