I picked up my R32 GTS-T last night, Only problem was the lights behind the dash were out :O
The guy I bought it off offered to fix but I wanted to drive it asap so I said I'd do it.
I'm sure its an easy job but I don't have the service manual yet (anyone know a source?)
The clock backlight works fine its just the gauges that are affected. If one of the backlight bulbs blows, I assume the others keep working? If so it means its just a fuse issue since all the gauges are out?
I checked the interior fuses and didn't find anything blown (though some were missing, probably the spares). I ran out of daylight to get to the engine bay fusebox. Does anyone know where the fuse is?
I really need to get that service manual :O
Cheers guys
https://www.sau.com.au/forums/topic/119681-dash-light-help/
Could be a stupid question on my part, but do you have a dimmer knob? Most Skylines have one installed by compliancers as part of the import compliance rules. Mine looks like a vintage amplifer knob. =-o
I fiddled with all the knobs ... erm wait... played with.... errmm...
the knob isn't turned down anyway :(
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2205923
the wires too the dimmer could have fallen off.. mine was very badly installed..
worth a check if you cant see any fuses out...
edit : does the air con unit and head deck dim when you turn on the lights .. if not that means it isn't getting power.. which would support the fuse/wiring issue rather than blown globes
Edited by Craved
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2205944
Ah! Good diagnostic there, Craved!
Definately try that one, it should confirm power for you, or as Craved said, check out the install of the dimmer. Getting that whole dash panel loose can be done by following the stereo install guides for R32's.
Check those fuses first, cause it's easier to do than loosen the panel.
(oh, and don't fiddle with your knob too much, otherwise it'll go stiff and you'll need to lube it up)
Edited by RANDY
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2206158
:sweat: @ Steve playing with his knob :) You know, you must be careful when you select knob placement. Never expose it unnecessarily - discretion is the order of the day.
Dude if it turns out you need to replace your dash bulbs, try http://www.skylinesaustralia.com/forums/in...howtopic=115618
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2206431
I checked tonight and the climate control dims when I turn on the headlights :cheers:
Looks like I'm taking apart my dash. I may aswell redo the entire thing in LED's so I won't have the problem again for a long time, just have to decide which color to go for now
Cheers for all your help
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2208430
Matt yell out if you need a hand. It's actually a lot easier than you think. I've just changed my climate control to blue (to match headunit). It's not as groovy as I thought - doing it again I'd probably opt for 1000mcd white LEDs to keep it all low-key. If you choose 3000mcd LEDs you will be more affected by the 'directionality' of the LEDs. That is, it will be harder to diffuse the light and make it appear more like a glow and less like a laser pointer.
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2210594
Hey dude if it was a globe only one would be out but because there isnt any light on the dash at all indicates the fuse is blown. It will be the fuse box in boot next to battery. Its the one that says tail light L i think it said. 3rd fuse from the bottom on the left side. Should be a 10amp fuse. Thats for a R33 but i guess the fuse in your engine bay would be same as mine in the boot so check it out before pulling apart ure dash.
Adam.
Edited by Woodys
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2220926
cowie165 -- Can you provide me some steps in how you did this. My climate control lights dont show up, so i would be happy to fix it and replace it with leds. Which exact ones did you b uy and from where? Also steps involved please!!
Ahh you got a 32.. Shouldnt be much different tho?? Or type of leds are different??
But please let me know.
Sidd.
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2222118
Sidd.
have a look here Sidd
http://www.skylinesaustralia.com/forums/in...opic=112729&hl=
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2223648
Sidd.
Hi Sidd.
The 'grain of wheat' bulbs are the same in R32 and R33. The link Craved posted would be great for replacing with 12V bulbs. I tried Jaycar unsuccessfully - didn't realise DSE had what I was after in 12V with wires only.
If you are interested in the LED route, this post and onwards has bits and pieces on how to do it. Very simple and effective. If your dash dimmer also dims the climate control, I recommend 3000mcd LEDs, otherwise 1000mcd with the 500mW resistor. As the bulbs are the same between Skyline models the LEDs will be substitutes also.
The steps and a few reference pics are in the thread/post below. I hope it helps :thumbsup:
Mark
http://www.skylinesaustralia.com/forums/in...dpost&p=2145079
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2225836
Ok im having the same problem with my dash i just recently bought the car, and it keeps blowing fuses for my deck and just today my dash lights dont work i also have pillar mounted tacho's and a monster tacho and they dont turn on either but when i put my car in reverse everything turns on normally? i had undercar neons (that were done pretty bodgy by the looks of the wiring and the on/off button) but i smashed my drivers door and the neon got ripped off and the wire is still haning under the car i have tried everything i can but i need help anyone with any information can you please let me know thanks
GTR-TZR
https://www.sau.com.au/forums/topic/119681-dash-light-help/#findComment-2227358
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
