Need one P1 Buddy club rim. Just wonering where to go to or if someone has one they want to sell?? Let me know asap. Looks like shit with the stodgy on the back.
They are 9 inch wide and are for my R32 gtst skyline
Even if there is a good wheel place or someone I can go through to get one.
Cheers fellas
https://www.sau.com.au/forums/topic/119690-p1-buddy-club-rim/
Maybe try C-red in WA, they are agents
Also try email buddy club, I did this ages ago and they sent me some details of a guy in Aus that they deal through
Mate if your in Tassie try Tru Wheels in Launceston on Bathurst street.
There is a also a guy in Devenport that does really good job on wheels. I have seen him rebuild ones that were compleat write offs. He can machine up new bits, weld and cast. I will get his number for you, but if you ring Bob Jane in Moonah, they have his contact details. They can arrange everything for you.
Edited by WogsRus
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
