Even totally warm, it takes probably 7 cranks to start. The old VL used to start at the flick of the key :\ tuner assures me it's totally normal though.
It is normal for the pfc's default values paired up with the rb30det, warm it should start instantly, cold it will take 2 turns or so. Well with the values below at least.
Here's the values I'm running now.
+80 - 10
+50 - 14
+30 - 22
+10 - 30
These values worked fine with the std rb20det injectors and gtr injectors.
All though cold starts 'could' be improved at least they start the car fairly well, not 7cranks. :D
I must say my Skyline has never started as well as my old VL. The vl was instant.
That sounds like a similar problem, thanks - should the AFM voltage be doing funny things when it is stuffing up?
You won't be able to tell the condition of the AFM by testing the voltages in this case. The voltages can read fine but the AFM can still be fubar. You need to get your hands on a swapsy.
+80 - 10
+50 - 14
+30 - 22
+10 - 30
All though cold starts 'could' be improved at least they start the car fairly well, not 7cranks. :dry:
Great help - thanks joel. :D
Will have a tweak over the next couple of days, because it really is a bit rediculous. I know if I had a close to flat battery and had to start this one in the morning I'd be buggered! Whereas my other VL will start cold instantly, all it needs is one crank and it's on, was the same on this one as well before I did the conversion.
haha well unfortunatly i had to get up in a rush to move my car for my housemate to leave for work, so my plan to put them in this morning was foiled :D
Will aim for tomorrow morning!
edit: this is probably a stupid question, but what exactly are we adjusting with the 'ms' ?
Edited by platinum
Those cranking values worked awesome - thank you so much! :D
Water temperature was 9 degrees this morning, and it turned over within about 2 cranks.
Now to take apart the AFM tonight and see if that fixes the other issue.
Which value did you use for the +10?
I now have mine at 35ms and very happy with the way it starts.
I've found a couple of little bugs in the pfc that I find it hard to replicate.
If I start the car and accidently touch the accel. while doing so OR almost stalling the car straight after starting the pfc appears to forget exactly where to apply the fuel cut.
It doesn't always do this but when doing the above is the only time when it may.
I slightly raise rpm and it fuel cuts until idle rpm then raises rpm again then fuel cuts.
Driving the car when its like this causes the car to jerk and cut out horribly giving you the feeling its going to stall, but it wont. :)
The fix.. Pull over, turn the car off and restart it. Drive off and its fine. As I said it only appears to do it when I do one of: Touch the accel while starting, or 'almost' stalling the car almost immediately after starting the car.
I came across the stalling the car bug when I had set the water temp correction maps too lean causing the car to almost stall when taking off at low rpm.
Unsure if other pfc's do it but my ap engineering one sure does. :D
This morning coolant temps were 10degree's.
I pushed the +10 up to 35ms, it took ~1second of turning over for it to spring in to life. There was no spluttering just a nice vrooom up to 1500rpm. :D
So the values helped?
i'll have to have a fiddle with mine, i'll try these settings!
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
