Does anyone on here know of a D.I.Y. for the drivers side airbag removal on an S1 R33 ?? Im thinking of changing the steering wheel, and i heard its a decent weight reduction of around 40-50kg ?
Anyones help would be greatly appreciated..
Thanks
Edited by MKDR33
https://www.sau.com.au/forums/topic/119730-drivers-side-airbag-removal/
mmm i dont think steering wheels weigh 40 - 50kg even with the airbag
you want weight reduction, take out the back seats, remove spare wheel/jack etc from boot, remove stereo, change wheels to forged racing wheels.
and maybe go on a diet and shed a few kilos yourself, every little bit helps
Not that i'm aware of. Last time we had the airbag out on my friend's car, i thought it woldn't have weighed more than 10 kg.
maybe if you got all the wiring and sensors out, it would be close to 20?
did you have to unplug/disconnect anything before taking out the airbag box?
