Sound.
You buy a cheapie exhaust and it's bloody loud. You get pulled over for it and have to deal with all the problems that come with a defect/noise/emissions notice.
You buy a more expensive JDM made exhaust (eg the Fujitsubo Legalis) that sounds nearly as quiet as stock. You don't attract unwanted attention with the exhaust noise and it may in the end possibly save your car from being pulled over and defected.
Sorry, but no.
Are Japanese manufactured exhaust systems designed to comply with ADR's and DB/EPA requirements? No.
Sure, some Jap systems ie the Fujitsubo and Trust PE II are quieter than others, but virtually ANY off the shelf 3 inch exhaust system will increase your exhaust DB to a level that exceeds the EPA limit.
Depends if you wanna spend the dough on the brand name aye, Sure I'd get a Fujitsubo/HKS/whatever brand name exhaust, but I don't have the finances to do so.
I spent $450 on a noname 3inch catback & hot dog resonator from Midas at Penrith in NSW. They mandrel bent the piping & painted the piping & muffler in matt black, I chose an oval exhaust tip as it suited the cut-out section in my rearbar.
It does it's job, sounds aggressive without being noticeably loud that the cops pull me over & I'm happy with it. :wave:
Sorry, but no.
All true but I'm guessing that although it will exceed the sound over the legal limit, it will do so less than a loud tincan style exhaust so the chances that you get pulled over will be less (less noticeable sound output)?
Also, are there separate dB limits for idle and WOT?
Think there is just the one limit. ie. 90 dB @ 4.5krpm? Correct me if im wrong
its funny how people only buy exhaust's to make it loud, i have a 3.5" titanium catback exhaust with a 4" cannon and its just below the legal DB limit. This way i wont have to deal with EPA, i get enough shit as it is from coppers here in Melbz anyway
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
