I have sorta done that with the R32GTST;
6 point roll cage
OMP drivers seat, std passengers seat, no rear seats
Sabelt 6 point harness
Bilstein shocks with coil over kits and Eibach springs
Whiteline adj stabiliser bars & alignment bushes
No HICAS
Nismo 1.5 way LSD
OS Giken twin plate clutch
RB25DET gearbox
Apexi titanium 4” exhaust
RB31DET with GCG version T04Z (~450 rwkw)
Oil cooler, 8.5 litre High Energy winged sump, remote filter etc etc
Power FC with Datalogit + Tech Edge A/F ratio logging
GTR alloy bonnet (all the fibreglass & carbon fibre ones I tried were heavier)
GTR front & rear bumpers and side skirts
17 X 8 wheels with 245/45/17’s Yokohama A032R’s
Brakes are standard R32GTST M 4 spot front callipers, with spacers on the front for 324 mm DBA slotted rotors.
Rear uses the standard R32GTST M 2 spot callipers with standard sized DBA slotted rotors.
Earls braided lines and Hawk pads all round
No aircon, but it sill has a heater for defogging
Ready to race (no driver) it weighs 1215 kgs
Other than the turbo restrictor, it is 100% Improved Production legal.
Basically I could swap almost all of that into an R32GTR, but I am not sure the180 kgs weight penalty would be offset by the 4wd in terms of lap times. The GTR would probably be faster over 20 laps, the rear tyres on the GTST cop a hiding. But over 1 lap, I am not so sure.
:dry: cheers :thumbsup:
PS, the Silvia with the RB in it is no lighter and has to put up with the crappy MacPherson strut front end.
  • Replies 148
Posted Images
lol looks like we will have the same setup except yours is in a r32gts with a shitload of other stuff
mine is the cheap poverty pack s13
s13 rb31det t04z
some shock and some brakes
might put a half cage in cause i dont comply for any race class just super sprints
i think i can beat your 1200 kg wet ready to go though
pete
s13 rb31det t04z
pete
I did the corner weights on a stripped out S13 drifter with SR20 a few weeks back. Weighed 1055 kgs, no driver with 1/2 tank of fuel. I know the RB30, RB25 box, GTR rear end etc easily weighs 120 kgs more than the S13 equivalents. So there won't be much in it I reckon.
:( Cheers :woot:
Why do you run the passenger seat? Just a restriction for the class you run in or is there some other reason?
Great to see the setup though.. While the engine is obviously quite a monster, the rest seems achieveable even with a moderate budget by the more amateur racer.
Everybody just seems to go straight for the GTR by default..
actually, I don't recall any freedoms in the IPRA regs for steering or rear suspension components that allows modifications to or removal of rear steering components.
not entirely convinced about the alloy GT-R bonnet either, but I'd have to check the regs on that. from memory, any component that is not 'free' must be of the standard material. I don't remember any rules specifically about bonnets (or other panels), so they cannot be modified/replaced by anything other than a standard replacement. You might be able to argue its standard for the model, ie by arguing the GTST and GTR are both the same model. that might be a stretch - but it depends on the wording of the IPRA definition of 'model'.
Actually, is the R32 GTST even an eligible vehicle for IPRA? GTR obviously is because of its Group A homologation, but the GTST??? ah, my head hurts...
There are models of R32 coupe that don't come with HICAS standard
There were 2 releases of R32GTST M with GTR alloy bonnets and front bumpers
Being a Late Model, front and rear bumpers and side skirts changes are legal
All models of R32/33/34 have been requested to be approved for IP racing, same as S13 was recently.
Since they are/were on the DOTARS list and comply with FIA Touring Car requirements there is no issue
:nyaanyaa: cheers :)
Edited by Sydneykid
I do quite a few drive days and have to take passengers/customers
Plus it needs a passengers seat for Sports Compact
Doesn't need one for IP racing of course
But does for Imported Cars classes in most supersprints and lap dashes
Doesn't really matter that there were some R32's without HICAS, unless the model your car is log-booked as didn't have it, you do not have the freedom to remove or modify it. If you log booked the car as a 'GTST M' you might get away with the alloy bonnet, but you would have to provide documentary proof that it was standard if challenged by a scrutineer. I didn't question the bumper fascias or sideskirts.
DOTARS list has nothing to de with eligibility for IPRA. To be eligible, the model must be either:
1) Group A homologated, or
2) have sold at least 200 units through a manufacturer's dealer network in Australia, or
3) be specifically recognised by CAMS for IPRA. The only models on that recognised list PRA are the Mirage Cyborg and Silvia S13.
BUT, I've had a look at an old 2004 CAMS manual at their definition of "model". It says:
"Model refers to a member of the same family of vehicle as produced by the manufacturer."
I think an R32 GTST is of the same family of vehicle as the R32 GTR, which is eligible (Group A homologated). So that shouldn't be a problem AFAIC. Would be worth a call to the 3J technical officer before you take that as gospel though. If they have put in a request to CAMS for them to be recognised, they obviously have a different perspective on that...
The car is log booked as an Nissan Skyline R32 Coupe 1990 model
I always carry the necessary paperwork with me, the car has been scrutineered for eligibility and 20 or so times at meetings
When you apply to have cars included on the list you need evidence/proof
The DOTARS list is proof of the car being elligible for import, nothing more.
Add that to the list of compliance plate holders as additional proof of eligibility.
Not all models of R32/33/34 are homologated, Nissan didn't think it was necessary
As long as they comply with Touring Car mininim dimensions that's not an issue
The list is constantly being updated (BTW; as manager of the race team I was the originator of the Cyborg in IPRA )
My best friend PL doesn't agree that the R32GTST is in the same "family" as R32GTR
We agreed to disagree on that point (glad to see that you agree with me)
So we moved on to getting them on the list, stops any problems then
:D cheers :D
PS; I just had lunch with the technical officer
Edited by Sydneykid
not sure what you are getting at there. the number of vehicles imported under DOTARS and compliance plate holders has nothing to do with vehicle eligibility for IPRA. Simply complying with dimension requirements of a touring car also does not make it eligible - it must fulfill one of those 2 categories in my previous post as well.
they release a bulletin each time its updated, obviously enough. It has been updated 3 times, but one of them was just because they couldn't spell Silvia :lol
:D cheers :)
look forward to seeing that bulletin release - as you say, it will remove any doubt. And it will make my plans for my old HR30 coupe's engine choice legal for IPRA! :dry:
I wonder what they think "member of the same family of vehicle" means if a R32 GTST is not a a member of the same family of vehicle as a R32 GTR :D surely R32 Skyline is the family of vehicle, and the various models (GTST, GTR, GTS4 etc) of R32 Skyline are members of that family? Its not like anyone's trying to say an R34 Skyline is the same family of vehicle as an R32.
oh well - wait for the bulletin. Would be good to see some other popular makes/model of grey imports on that list for IPRA too.
rb30 bottom end with a t04z, just built one for a friend it reaches full boost by 3100rpm and revs all the way to 7600 with standard cams and makes a tidy 370kw atw on only 18psi yet is very tackable and has huge amounts of low down torque. I would run a dry sump setup also and try to get 285+ size tires under the thing. Along with the other stuff people have mentioned in terms of weight and cage etc etc. That would make a killer track car!!
did you convert to single throttle set-up or maintain 6?
yes thats me.
nice to meet you.
1.21.2 was done with maserati club though.. www.masertclub.org.au (most recent sandown results-april i think)
ahhh I thought so.
Nice to meet you also. A friend of mine Simon and his father race a 944 with the porsche club, so I've seen you out a fair bit. Beautiful car mate, great to see an RS being used as it was intended!
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
