It was a good night, I guess.
At least nobody has made any jokes about my one-eyed, purple headed monsta. Sure woulda been nice to have 20-20 vision through the twisties.
For those who didnt know (and I do NOW) the GTR has separate fuses for left and right headlight assemblies, and no fortune spent on new globes will fix a blown fuse :nowigetit:.
  • Replies 85
no worries erin .... it just gave us a chance to open it up in the hills to pass you :D Sorry I didn't get to introduce myself .... there's always next time!
Paul .... u eeeeeeeeediot - all that wasted time - not to mention the knuckle crunching. Oh well at least it's fixed now and not some major problem!
Brad .... sif me keep up with a $100,000 GTR pfft :(
Andrew i meant when u got left behind the whole pack and we were waiting and ringing. Not about whos got what and how fast it as. Dunno what happened and doesnt matter to me, maybe u were talking to some one and got left behind at one of the stops.
Either way all good m8.
hehe yes I stayed behind to help Paul install his new headlamp globe - to no avail. Then drove slow (so he could keep up) in front of him so he had some idea where the road went .... it would have been darn hard to see with only one fogged up headlight! :(
Then we had a slight detour nearly to Mount Torrens before coming to meet you guys at Hahndorf Subaru .... you guys nicked off down the freeway and disappeared after that - we went into town, did some laps and let some smoke out of my tyres (they are still very full!) :D .... too bad you missed it!
Matt/Diggity - how was JMS after?
Pity about all the waiting around. But still a good nights cruising.
John - Thanks again for the strap in the beast. Really appreciate it.
Was good to meet everyone and put faces to names.
Can't wait for the next cruise.
Stuart - Passenger in the 200SpecR
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
