my mate will spray it free and ill fit it so a bonus there :D
if that is with the bottom lip its probably not too bad a price, i want the one identical to yours with the holes, any idea of the vin number of a car that came with one standard?
Edited by 2630GTS
Those holes are N1 vents. To get a genuine GTR N1 front bar costs a packet and they are rarer than you can imagine, and Nissan will not sell you one. The genuine vents are worth like $300+ (just for the vents) but few people have real ones. Mock ones can be found starting about $50 on ebay etc.. A genuine GTR fr bar will not have indents for the slots at all so you would have to cut them out... not sumthing you want to get wrong!
There are comapnies that make fakes for like $550 they have indents, so you can pop them out and buy some vents to put in there so thats about $600 before paint and fitment..
im pretty sure it is a nismo option rather than only fitted to n1 32gtr's, they are simply too common on gtr's. im sure many owners could confirm this.
ill give nissan a call tomorrow cheers :D
You could option them from nissan when buying the GTR also, but the vents are called N1 vents. The genuine vents themselves are worth HEAPS. And I promise you Nissan will not be able to help you with them. Mine are fake, 32line's are too, another friend I know had them and they were fake. They are common because a lot of people get the fake ones.
Hey Rekin nice rims I am keen on these from Just Jap, what size and offset are they?
Thanks :thumbsup:
17x8 +30
17x9 +30
I might have some troubles lowering the car as the rears stick out a fair bit. Dont think its an issue with the GTR's but :huh:
Are you sure the guards will need to be flared?
Ive got 19 x 9.5 with 265 rubber on the rear. Apart from the guards being rolled, I certainly dont have them flared..
Got a couple of cool photos ;)
Edited by Yidz
I've got the same wheels, same size and lowered.. so U need to roll and flare the rear guards
Cheers
rolling i can deal with, but not really keen on flarring..
Can you post a pic of a closer look at the flarring?
Also how low is your car from centre to wheel arch?
I think my shocks will drop the height to 340mm and hope i wont need to flare..
Thanks
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
