u barstard rekin.. lol.. its k ill probly keep looking around or contact nisswreck..
cauz im getin my respray soon and i would hate for that lip to be all flakey when i get it back.. i will post when its all finished..
thanks for the link rekin
heres my ride from lastnite.. went black spurs to scope out some locations for my up comin GTR cruise.. had a couple of my evo boys come along :)
this is the extremely reduced version (was 58mb... now 135kb lol )
When I was gunna get mine resprayed i got them to sand it back with the front bar and just paint it all as one, but then I ended up with a GTR fr bar instead.. But I still have my type m (from 93 model r32) front bar with fog light all sanded back and primed which I was going to sell as I have no use for it now..
i would of liked to see it same colour as the car.. but i was thinkin it might be too much.. thats y i wanted to keep it stock shadow chrome colour.. but i have the type m front bar too the think im looking for is the little strip in original shadow chrome.. or a place that will do it..
thanks for ur reply r32line.
a 400D and 5mgs?? thats coz its a jpeg... in the CR2 format its about 10mbs and when converted to a lossless format eg TIFF, it becomes roughly 58mb.. but then i editted it, made it smaller and saved it to a lossy format JPEG which is shithouse quality but good enough for forums
Hmm cant really say I'm a huge fan of that lip. Looks a little off balance with the rest of the car. I think with a decent full car kit it could look good.
Interesting :P Don't know enough about camera's!!
I think this is that lip. Well it was.. it's now in two pieces...
NUHHHH were not talking about that lip.. its not an addon.. its on the stock 32 gtst bar... see where u have the grill from the GTR.. thats were it is.. cauz the GTR bonnet dosnt lip down..
but anyways sorry for destracting everyone on this topic.. lets get back to the pics..
Edited by Fugi
he's talking about the lip on the bottom of the bumper, its another conversation goin in the thread :)
You have half a shell in fiberglass there funky.
Super light weight race 32/goggo mobile.
Current work in progress:
GTR front guards and bonnet installed, i'm keeping the goofy stock front bar for ground clearance. The wheels on the car in this pic are 17x8+30 with a 25mm spacer behind them.
New wheels installed, NS01's in 17x9.5 +15 with a 5mm slip on behind them to fill the guard. I think it's another one of those wheels that look a lot better on the car than off. I think it looks pretty bloody good, but the tyre is a bit stretched. really need a 245 on there.
next step: gtr indicators, step after that: flared rear guards to fit the rear wheels
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
