Hey fellas last pic i posted up was a photoshop to see what ppl thought of the height.Well my car is now at that height so i thought id post up some pics of my pride n joy from the SAU Megalong Valley cruise
Gee mannn!! it's look nice and low, i could say.. perfect height for 32 mate
well done and good job!
man that looks insane, I love it
What are the specs of the wheels?
The wheels are Axis deep dish 19x9.5s with 265/30 zr19 rubber.Not sure of the offeset as i have to run spacers.Im really happy with it now ay
Edited by Travis32
Thanks mate.I think its insane ay.Its taken me a yr to get it to its present state so im finally happy with it
Any scrubbing?
Mine has similar size rims and scrubs like crazy atm. Hate to say it but mine needs raising! lol
Looks phat. Good work.
Hey mate.Yeh thanks.Sits nice now.No scrubbing at all ay.Ive had my front guards pumped and my rear guards rolled.The only slight problem i do have is that my exhaust sits abit too ow so ill get my mate to make it a bit closer to the floor.
Edited by Travis32
Very nice car 32Line... What wheels are they? Look awesome!!!
Hey Travis, yeah looks good. Well I'll have to get my guards rolled a bit. Definitely want it as low as yours. It looks porn.
Yeh no worries mate.Did you say u had 275s?Depending on ur offeset you may scrub.But if ya pump the front guards far enough ull be right.Rear guards should be fine if ya just roll them cos once you lower it the guards just swallow the wheels
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
