R32 Pix Only
gts-t 4 life
Hey yawn put some pics of your car up man im interested to c what it looks like?
Not sure what's changed from these pics.
I can't find the larger pic of his avatar though. hahah
Hahah did you go thru the thread to find those? I was looking for em the other day and I couldnt even find em myself :whistling:
Nothing much has changed since then, only under bonnet stuff.
The only thing else you can see from outside is the rear windscreen has now been tinted privacy glass style, and a different intercooler.
Ill get a pic of it up soon, but the paint on the front lip is farked.
Edited by Yawn
Hahah did you go thru the thread to find those? I was looking for em the other day and I couldnt even find em myself :laugh:
hahahah I remember commenting on your car in this thread. I just searched for posts made by you in the thread and found them. :banana:
looks tuff man, got much work done?
My beast, fairly standard looking with n1 skirts, just the way i like it.
Looks nice man, P1s suit it well
Fairly standard.. R32 GTR exhaust, apexi pod in encllosed box, FMIC, catch can, boost wound up, whiteline/blistein suspension + whiteline sway bars, RDA slotted rotors.. got a split dump pipe and bosch fuel pump to put on
is ur suspension in or were u really pushing it round those corners?
its just the corner.. you come down a hill and hit the corner hard
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
