hey fellas just thought id put some more of my beast up.Cos i love it lots lol
Also the dodgy pic is of a set of side skirts im thinkin of gettin custom made.Be good if yas could give me ur thoughts of what ya think
Snore :(
Hay my r32 people have not been on for a long time car has been off the road for 14 months.
has hade full rebuild 10k spent.
Was just put on the dyno and made 230rwk at 13 psi
some pix for you all.
    • Yeah good point, it won't flash on indicator that way, so plan B, just another wire to run from under the dash which makes it a bigger job 30 to indicator + globe side 86 tapped into 12v input to flasher relay under the dash (has 12v when indicators on, nothing when no indicators) 87a to headlight parker + 87 to original indicator + chassis side 85 to chassis/earth Now it will flash with indicators and be solid on with parkers
    • FWIW, that's the only colour I'd buy it in
    • I am having issues I believe with the throttle body. The butterflies only open about 1mm on the bench at full throttle. Is this what is supposed to happen? does it use the motor for the rest? I am able to manually open them up the hole way but it sounds like it is on gears.
    • Currently at 380rwkw with 2860 -5's & b cams on e85, trying to make it have a bit more torque/usable power down low.    Ive googled the v cams and most sites say discontinued, is there anywhere you can still get them?
    • Most hardlines are available new still. But unless they're rusted to the point of needing replacement you can just zinc or cadmium plate them to keep them going for decades to come. Regarding the turbo drains it really depends. Braided lines might be better if it's a straighter path than OEM but I would not assume braided teflon lines will never leak. Teflon is a very durable material but you can still abrade, erode, or otherwise compromise its integrity. The return hoses on the bright side are not that hard to access relative to a full turbo removal so if things go wrong you can always put it back to stock. You can very easily drive yourself insane analyzing every little change, or maybe that's just me.
