cheers Josh
when you have the bumper skin off and look at the reo bar bolted to the chasis, you'll notice that the two front bolts on either side bolt through a O shaped cutout, the rear two on either side slide over the bolt with a U cutout in the reo. Just need to make the front O shaped cut out 12mm in length longer so you can slide the reo foward
I did it with a die grinder as its alot easier than trying to drill it because of the thickness of the metal..
