are you planning on using bolt on guards, flares or hand flaring the guards to fit the rims?? with some stretched 245s or 255s you will come close but will still need something done... im keen to see it when your done if you are hand flaring it... thats gonna look awesome, nice wheel choice
took a couple shots this arvo and tonight, heres a few i mucked around with. Hard trying to get them looking nice without going too far :S, not sure if i did or not.
I included a few of the crappy night shots so i can get some advice :cheers:
so the night shots r shit, any tips ?? i'm pretty sure the blue spots are reflections from the HID's on the lense, hence how they can float in the sky haha.
I know i need to get a tri pod to start with for the darker shots, i didnt get a single one correctly in focus.
I also tried out my new flash tonight, nice wireless one. I tried it to the left of the car, directly infront of the car, behind the car, and at my feet, all set ups resulted in either a totally black pick (behind) a huge white spot and a shadow on the wall (to the left) an over exposed crappy look (in front) or something else, how can i correctly use this flash to better low light shots without shadows and over exposure ?. i should get a tripod for the flash too. I figure theyre generally better if you have 2 so they can correct each other ?
any tips much appreciated :D
post-22805-1226068188_thumb.jpg post-22805-1226068202_thumb.jpg post-22805-1226068215_thumb.jpg post-22805-1226068228_thumb.jpg post-22805-1226068239_thumb.jpg post-22805-1226068355_thumb.jpg
haha nice nice
How much power did you make with the RB25 turbo, heaps better to drive now?
I made 186.8kw @ 13psi. Yeah it is heaps better - Comes on a bit later than standard but makes up for it on top end as it holds 13psi and pulls till redline. It's good fun :D
    • Done about 5k Km on the PS5's now, excellent street tyres, great in the dry, and the wet, seem to be wearing very well, I haven't measured tread depth, but it looks like minimal wear, I also had a different alignment done about 1500km ago,  From looking at the tread wear, which is really only minimal, the alignment changes were based off how the tread looked, and how it felt throwing it around, the changes have shown great results 215/45 17 at 32 psi Front Caster: 5.5° Camber: -1.5° Toe: 0.0mm Rear Camber: -1.0° Total Toe-in: 1.5mm I actually prefer PS5's now over the RS4's, as the PS5's are much better in the wet IMO, and as the MX5 gets driven in all weather conditions doing daily duties, hwy trips, and blasts in the mountains, wet weather grip is high on my priority list
    • To update this thread. I got sent a replacement Attesa pro unit and all is now working as expected. Cheers
    • FD is so sexy she can pull off tri-spokes
    • Indeed they do. Best my diff builder could tell is it's a combination of the different cut/angle and it would seem they lap them in well on accell but less so on decel. He had to use a slightly different pattern to the lap to get the best result noise wise. Also as the rear diff runs in, the whine is getting less.        Overall they seem like a good thing so far. He's done a few neat crown/pinion before but all for race cars with loud everything, in most cases the exhaust is louder, so I am the first to notice.... and be somewhat of a pain
    • What do you mean by "test"? It sounds like you're just switching things on and off that you already know don't work. Get the wiring diagram and a multimeter and start looking for power where there is supposed to be power and earth where there is supposed to be earth. Look for continuity across switches that are otherwise unresponsive, etc etc.
