R32 Pix Only
gts-t 4 life
That's hot man but your front bar looks warped?
What sizes and offsets are those wheels?
Yeah it is a bit, looks worse because the photo is shot pretty low. Brought two of them for $250 and sold one for $400 so I'm not to fussed.
The wheels are:
Rear - 18x9.5 +18 215/40
Front - 18x9 +13 215/40
took a couple shots this arvo and tonight, heres a few i mucked around with. Hard trying to get them looking nice without going too far :S, not sure if i did or not.
I included a few of the crappy night shots so i can get some advice :ph34r:
post-22805-1226068188_thumb.jpg post-22805-1226068202_thumb.jpg post-22805-1226068215_thumb.jpg post-22805-1226068228_thumb.jpg post-22805-1226068239_thumb.jpg post-22805-1226068355_thumb.jpg
oo very nice!
How did you get your black paint so shiny in the first pic?
The wheels are:
I can't believe you managed to stretch 215's onto a 9.5" rim. No tyre shop I know would do that and I know people that work at one!!
I was running 215/40/R17 on the front of my XD9s which were 17 x 9.5 + 17 and 225/40/R18 on the rear 18 x 10 + 18 :banana:
Some serious stretch
Here's a couple shots of how the wheels sit and tyre stretch, still need to sort front and rear camber. Was running 225/40 before these but they were rubbing quite a bit, might just be the design of the tyre there might be a 225/40 out there that fits a little better.
what size and offset on those rims? look tuff!
Front - 18x9 +13
Rear - 18x9.5 +18
You should be able to get away with that on the back
I had 18 x 10 + 18 on the back of my R32 with 235/40 tyres. The inner lip on the guard was rolled and we slightly pumped/flared the whole guard, not to much but just enough to tuck the wheel under
Fron't I had 17 x 9.5 + 17 with a 235/40 tyre and same deal, guard liner removed with the inner lip rolled and guard slighly pumped/flared
Man, you guys all freak me out with the size wheels you are jamming in under the GTSts. I want to run a 9.5" , maybe 10" rear but only because i want to run a 265 rear tyre :down:
Anyway, the car has 9" +20 offset which should be doable and when the guards have been pumped for that sized rim i should be able to get a 9.5" + 36 on the rear aand run 255 tyres.
Is anyone running wide rims with decent sized rubber?
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
