Got new rims for my GTS-t
the front lip is nice, where did you pick it up from?
Do you likes Like this idea or Not?
Original Skyline Badge
or
Just GTR grill?
cheers-
The original skyline badge looks nice, put some black mesh behind it and should look mint.
Any chance you live in Noble Park? Every morning I see a silver r32 with the black lip you got, you also did it on the back of the car?
^ Dunno man, I can't really see it. Both gts-t's had been resprayed grey with tint... the one on the right was bought like that... the paint had been put on quite some time ago though, if anything paint was starting to fade.
You will have to put up some pics when your car is done!
I'll do that :bunny: Just got the doors to do and have got some graphics designed for it that I'm going to 'ghost' onto the side.
Was curious about the lines because I found the grey metallic I'm using really sensitive to overlap, to the point where I'm probably gonna do the roof again. It's got faint lines in it and I'm a bit of a perfectionist :banana:
I really don't know anything about this front lip not even the brand. It was on my bumper, when it came from Japan.
Sorry mate
its awesome tbh, makes the normally FUGLY series 2 front bar look decent :/
Just had coilovers and swaybars put in (TEIN super streets and the fattest swaybars whiteline had to offer, fantastic upgrade :D) so thought id take some pics, also sat my N1 lip on there for the pic lol, not painted or fitted yet though, going to paint this w/e for the lip, ganadors and some minor scratches and cracks.
From here i just wanna get a GTR front bar and some new rims, either CE28n's or SSR type F's and the outside is done :D
p.s. shitty pic with the half sun/half shade, oh well ;)
Haha!!
So good, Bumble Bee...
True that!
hahaha yeh it gets called that alot, yeh i blow up the rb20 n got the motor loom and ecu for 3k i picked up a gtr box for 200. yeh i cant wait to drive the 26. it was awsome with the rb20 in it lol i just need my kevin rudd money then i can get it finished =)
Edited by rowan
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
