more details on this thanks.
i have a write up on this car in an option mag a mate brought back from japan. i cant read japanese but they have enough english text to get the idea.
it had a faster track time than most of the GTRs in the lap battle. looks different with the bolt on guards and he has made some smart but sensible mods to get the times it gets.
ill try and find the mag and list the details.
32s i found on the net. my 32 is black with stock rims haha
local track radial tyre record holder (in japan) lightened to just over a ton and RB20 with 25 turbo.
cheers
the write up in an option mag on this car lists the following (what i can make out)
Rb20DET
310ps
Nismo GT LSD
R34gtt calipers (30mm bigger rotor diamiter)
Endless or project Mu rotors
Front spring rate 12.3kg
rear 10.7
toyo r1r tyres 255/40 f&r
Rims front 9.5jx17-28
rear 10x17 -32
body widened 50mm front
100mm rear.
cool looking front diffuser
it does 1:1.705 around Tsukuba
Rb20DET
310ps
Nismo GT LSD
rear 10.7
rear 10x17 -32
100mm rear.
so f**king cool.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
    • Just chuck in an ECU, Injectors and a pair of direct fit low mount turbos, that should use to the top of your budget and give it a nice kick along. Also, don't do anything unless you don't need the car daily....if it does blow and you get another 10k bill just to get back to where it is now would you be able to come up with the cash or will it sit for 2 years like most GTRs....
    • Thank you 馃檹 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 馃
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
