Here is my car turned around and getting ready for the gear box to go in soon
I will do a build thread for this car soon enough. The 30/26 is just about ready to go
The front bar is just zip tied on at the moment but it will be held on correctly soon. Im just going to a friends place who has a hoist to put the gear box in and will do the bar at the same time
Edited by waxracing
my hcr32
with 18 inch alloys wich I do not prefer as they are very weighty and a tad oversized
but still not happy with how it looks atm, needs serious lowering + 17inch dished alloys, but since I'm using it as a daily driver, and my front lip is already kissing the 15 speedbumps I have to cross every day, it will be scraping like hell :nothappy:
Yes I know it needs more low.
First track day at Sandown, cars best lap was 1.27.10 on kumho ku36's
Active aero front grille :) Needs more self tappers
Heathcote drags 13.10 @110mph on same tyres (yes my rear door is a different colour)
  Mohsen said:
dude what are your wheel specs?
there they are 17x9 -5 F and 17x9 +25 R, atm im running +10 at the rear, and ive lowered the front as well as pulled the guards out further to clear the wheels at the front. when ur running as much lock as i am with 235/45's u kinda have to push them out wide like that. they sit a lot better now tho.
  Mohsen said:
dude thats tough as
would you know what size you would need to get it flush without pulling the guards
(sorry for the thread hijack lol)
with stock guards? 17x9 +20 is mint with stock camber arms and low.
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
