R32 Pix Only
gts-t 4 life
Yea mate! Enkies are the SHIZNIT.
@r32impul, what are the specs of your Enkei RP-01's?
the Enkies RP-01 is 17", i fit 255/50/r17 tyres
most of the Group A GTR in Japan is fitted that size on the track
the Enkies actually have a word "close circuit used only" marked on the rims. It is very lightweight and have hips of clearance for the brake.
:action-smiley-069:
Jenkies, where's the Nismo LMGT wheels?
You got Enkei's now..?
BTW your car can go lower :D
hahaha, found the rpf1's at the right price 10.5 wide :D, its got the old rear coilovers in while the currant ones are being rebuilt(oldies sit high). front is scraping as it is. need to roll guards
r32 impul: what size rotors are they? same as my old rims!
hahaha, found the rpf1's at the right price 10.5 wide :ph34r:, its got the old rear coilovers in while the currant ones are being rebuilt(oldies sit high). front is scraping as it is. need to roll guards
I see, haha!
BN
Does look tough!
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
