R32 Pix Only
gts-t 4 life
Roy what is that thing that is in front of the turbo and under the line from the rocker cover to catch can? Looks like a water bottle? >_>
LOL, yep. I had it there to put the turbo oil feed line to so that I could confirm oil flow before cranking the engine over
RB20 having some fun :)
MINT!
Here's the latest for mine. Just finished getting a gtr bar cut, welded an fitted :D
Cut? Welded?
Youwotnow?
Gtr bar is like an inch wider then the gtst, the body shop cut an plastic welded it so it'd be a real flush an straight fit :-)
What wheels are they and size? Love em. And car looks good. Not sure about the driver :)
Cheers :D, sorry for the late response, Enkei RPF1's 17x8.5+30 on the front 17x9+30 on the rear (It's a gtst so going by your profile, you'll want different sizes/offset for your r) ;)
Not sure if these have been posted before, but...
I love R32's in white, even non GTR's look sexy in white I reckon. lol.
Dunno, makes 'em look fatter in the bum.
I almost bought this car back when i was still trying to decided between an R and gtst
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
