Roy what is that thing that is in front of the turbo and under the line from the rocker cover to catch can? Looks like a water bottle? >_>
LOL, yep. I had it there to put the turbo oil feed line to so that I could confirm oil flow before cranking the engine over
RB20 having some fun :)
MINT!
Here's the latest for mine. Just finished getting a gtr bar cut, welded an fitted :D
Cut? Welded?
Youwotnow?
Gtr bar is like an inch wider then the gtst, the body shop cut an plastic welded it so it'd be a real flush an straight fit :-)
What wheels are they and size? Love em. And car looks good. Not sure about the driver :)
Cheers :D, sorry for the late response, Enkei RPF1's 17x8.5+30 on the front 17x9+30 on the rear (It's a gtst so going by your profile, you'll want different sizes/offset for your r) ;)
Not sure if these have been posted before, but...
I love R32's in white, even non GTR's look sexy in white I reckon. lol.
Dunno, makes 'em look fatter in the bum.
I almost bought this car back when i was still trying to decided between an R and gtst
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
