WoW, beautiful. Your car is amazing
Engine bay is so tidy and clean and the outside immaculate.
really impressed with your effort
Thanks Richard ! I do try to keep it as clean as possible
See you at the 25th anniversary meet?
Thanks.
Over 200 hours. Easy, i dont really know. Over 6 months.
But it shows you really can polish a turd. ;)
How to:
Disassemlbe as much as possible, wash, sand 40 grit to help the paint stripper, tape and mask up the car, paint stripper x2, wash, panel beating, wipe with prepsol then a tack rag, mask up, etch primer, bog, sand 120, bog, sand 180, dust off, prepsol, tack rag, mask up, 6 coats spray putty and a guide coat, block sand 400, bog and skim putty, guide coat, block sand 400, wash, prepsol, tack rag, if its good now you can mask up and do a coat of primer/sealer, a light sand 800, dust, 6 coats of colour, light sand 800, dust, prepsol, tack rag, re- mask, 1 coat of colour, 6 coats of clear, wait a month for it to cure, sand very carefully 1200-1500, coarse buffing x2, medium buffing x2, fine buffing, lime prime light to prep the paint, hard wax, soft wax, sealer, recondition the rubbers as much as possible, clean and detail everything else, polish all the fingerprints and dust off, park in the sun and admire.
Thats about as short as i can describe it.
  • Like 1
Oh lordy a commodore ute on SAU. I did not think I would live to see the day :P
Blasphemy
may Rajab not be a watching as an anonymous user or we will all perish ................
Edited by Sinista32
  • Like 1
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
