You can afford to raise the height of the car, easy fix for clearance
She drives really well thanks Bobby.
There's a li'l bit of scrubbing on the front tyres, so I'm thinking of lower profile or rolling the guards (which I've been told not to).
I think we might meet at some stage time/commitment permitting.
Again, thanks to all of you guys for support - the more warped it is, my humour appreciates it.
I run the 255/35 on the front. Mine are rolled.
Honestly Terry I'd have the front slightly rolled.
If it's the original paint and guard warmed before rolling there will be no paint flake.
(Resprayed guards and doing them cold will cause that crack and flake to happen)
Thanks for your input to Mick.
So it looks like...
1) tyre change to 35 profile
2) source progressive springs to suit Bilsteins > raise car
3) yet to be considered > guard rolling
Terry showing off again
Clicked over 50,000Kms today.
Even as a kid, I used to love things that glow in the dark.
One of the things I'd purchased before receiving the car, thinking, "What do I need a glovebox for anyway?"
Not sure if I'll be looking over to the left that much though...
  • Like 1
The rack Richard makes it (the R32) feel heavier than what it is. Or the corollary: the R34's rack makes it feel lighter than what it is.
Yes I like its 'rawness' a great deal. The R33 (which was my first GT-R) had a bit more oversteer which I actually liked.
I'm glad that I have upgraded the brakes, rotors, brake lines and castor rods on this R32.
Very well behaved. This is my 5th GT-R.
The 35 profile tyres have now eliminated scrubbing (compared to 40)
Thanks for asking :)
another N1 with A/c in it
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
