Just spent 5hrs washing, claying, polishing and waxing car.
Not happy with the autoglym super resin polish. Didnt cut enough. Need to use a stronger cutting compound to restore my paint.. hehe
Too tired to get proper pictures, maybe tomorrow
Mothers Clay bar
Autoglym super resin polish (waste of $30 -_-)
Mothers PowerWax
Phaw!!! Looks mint! i wouldnt change a thing
Thanks mate. It's like a brand new car. Less than 60000k's with full service history, and less than 20000k's since 1996.
Not really planning on changing anything which is damn hard when there's a GTR in the garage :-)
Maybe the wheels, and I'm adding an oil cooler next week for protection, but that'll be it i think :down:
Mothers Clay bar
Mothers PowerWax
Looks damn good in my books mate.
I have never really understood what the clay part does though.
Thanks for the comment :)
if you run your fingers over the paintwork on your car, you might feel a lot of bumps which you cant see.
Claybar is a peice of clay which you slide across the paint which sticks to these bumps(microscopic dirt/imperfections) and pulls them out of the paint. Leaving a real smooth paint afterward.
Rekin, looks tops mate :)
I can't see what you're worried about from those pics. Paint looks pretty good.
haha, wasnt too impressed over the autoglym super resin polish. $30 for 375ml's expected a real good cut.
Although reading some fine print on the internet, they say to do 2-3 coats of the polish to get a good result.
Although it be quite hard to squeeze 3 coats out of a 300ml bottle...
Just finished washing my car and decided to take a few shots. Should have taken it out of the shade
This is my new car that should be here in the next 2 months as long as everything goes to plan.
1993 R32 GTR vspec ;)
Edited by babyskyline
