are you planning on using bolt on guards, flares or hand flaring the guards to fit the rims?? with some stretched 245s or 255s you will come close but will still need something done... im keen to see it when your done if you are hand flaring it... thats gonna look awesome, nice wheel choice
took a couple shots this arvo and tonight, heres a few i mucked around with. Hard trying to get them looking nice without going too far :S, not sure if i did or not.
I included a few of the crappy night shots so i can get some advice :cheers:
so the night shots r shit, any tips ?? i'm pretty sure the blue spots are reflections from the HID's on the lense, hence how they can float in the sky haha.
I know i need to get a tri pod to start with for the darker shots, i didnt get a single one correctly in focus.
I also tried out my new flash tonight, nice wireless one. I tried it to the left of the car, directly infront of the car, behind the car, and at my feet, all set ups resulted in either a totally black pick (behind) a huge white spot and a shadow on the wall (to the left) an over exposed crappy look (in front) or something else, how can i correctly use this flash to better low light shots without shadows and over exposure ?. i should get a tripod for the flash too. I figure theyre generally better if you have 2 so they can correct each other ?
any tips much appreciated :D
post-22805-1226068188_thumb.jpg post-22805-1226068202_thumb.jpg post-22805-1226068215_thumb.jpg post-22805-1226068228_thumb.jpg post-22805-1226068239_thumb.jpg post-22805-1226068355_thumb.jpg
haha nice nice
How much power did you make with the RB25 turbo, heaps better to drive now?
I made 186.8kw @ 13psi. Yeah it is heaps better - Comes on a bit later than standard but makes up for it on top end as it holds 13psi and pulls till redline. It's good fun :D
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
