hey ZENNON are you able to tell me what brand the wheels are on these to cars. they both look like the same wheel.
are they by chance Origin DNA-01 wheels?
ABU???
oh and a current pic of my car as i have not yet added to this topic.
I'd trust a brand new set of Drift Teks over a second hand set of Jap rims anyday, who knows what second rims have been through.
unless they have copped severe damage, the metal properties will still be intact and they will have most if not all of their original strength.
if the 3nd set of jap rims spin up fine on a wheel balancer id trust them more than drift teks
one word for most jap rims - FORGED
actually, only a very small amount of jap rims are forged.
suspect they are DTM Rush Shadow Silver's
link: http://www.skylinesaustralia.com/forums/Jd...in-t205654.html
ps. SoFly - very sexy :D
ps. SoFly - very sexy :ermm:
well there you go. thanks heaps for the link and info.
they are very similar but not the same as the DNA-01's. the DNA-01's only come in 17' as well. they would be close enough thoe if you wanted 17" front and 18" rears.
i have a pair of DNA-01's on the way for my car and if i like them i will get a few more. i cant wait to post up the pics.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
