here is my little project.
this thread is my inspiration.
going slow, trying to get it prepared for paint, best i can with tools i got.
stripped all the paint out, and started from scratch, hopeful to get engine bay and boot done this weekend, and some brackets made to flip it over in the coming weeks to paint underneath.
more info in my garage.
http://www.skylinesaustralia.com/forums/in...mage&id=615
http://www.skylinesaustralia.com/forums/in...mage&id=616
I HATE PAINT...
Edited by 32_Dave
is that the dmax boot spoiler you got on the back?
yep it is. looks pretty neat. i am also going to get a roof spoiler as i dont want to run a GT wing.
As far i i know D-Max stuff is getting scarce as the people i got this off had to change suppliers twice and then it was the only one they had. it seems that there is a lot of issues with D-max aus.
i seen recently that Viva garage sells the roof spoilers cheap as chips. much cheaper than D-max. even thoe the last Viva kit i got was worse than rubbish ill try them again.
well here are some pics of my new gem.. picked her up for a great price off an old mate for 9K as she sits. Former owner has spent over 8K on mods in the past year,
such as but no limited to;
HSD adjustable coil over suspension
Adjustable camber arms
Adjustable control arms
Solid Cradle Arms
(only thing that hasnt been touched is the sway bars.)
18" gold speedy ( Volk GTC copies) Mags
Sandard turbo but highflowed by GCG - Ball bearing 500hp
Walbro fuel pump
Cooling Pro FMIC
Oil filter relocation kit
Greddy Oil Cooler
Greedy Catch Can
Engine Dampner
Strut Brace
Stainless Turbo Manifold
3" Turbo Back Gutted Exhaust
Shimmed diff
NPC 5puck clutch
Short Shifter
ADR approved Blits Fibreglass vented bonnet
It pulled 183rwkw @ 13.5psi and had steady but rich AFRs, I have upped the boost to 15psi and its running sweet yet to dyno it on 15psi yet. I have R33 GTR 444cc injectors and Z32 afm waiting to go on once i obtain a Power Fc for the right price.
anyway here is some pics of my new sex on wheels
