  • 3 weeks later...
new wheels 18x9 Xd9s
Uploaded with ImageShack.us
nice looks clean and roadworthy :) no issues from authorities,
but if u do decide to upgrade,
XD9' in;
17x9.5+17 with a 215/40 profile tire up front
18x10+38 with a 235/40 profile tire on the rear
fits perfectly on a R32 Gtst with rolled guards :)
my new toy.
building it for track work.
post-39965-0-43604800-1292634791_thumb.jpgpost-39965-0-51166800-1292634823_thumb.jpgpost-39965-0-60380700-1292634847_thumb.jpg
whats your thoughts on headlights tho??
im undecided.
the lights are definatly different. a mate of mine did the same thing about 4 years ago but recently got defected and had to put it back to stock.
i think if you made a perspex cover that had the same shape as the original headlight it would look good.
i particualy like the black door handles on the white. ive always loved black and white mix on a 32 thoe.
This is my 32 had it for about 5 years now its almost there done a 2jzgte conversion that been in there about 2 years getting ready to do a E85 tune hoping to get close to 550hp at the wheels
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
