This is what it's like in Canberra today - Just put it up as my desktop background - nice and calming. wish I had put my grill in today but gotta do the AC regass so easier to leave it off till nxt weekend.
can i have ur front indicators lol theyre so hot
just one question with all do respect what entice's ppl to destroy their rear guards on the nice gtrs?
who knows, maybe for the same reason your GTR is slammed and running the body-kit/wheels it does?
a lot of different tastes on this site
Here is mine.
Currently getting a engine rebuild which should be finished in the next week or so.
I also have a build thread as well if anyone is interested
Looks absolutely awesome!!!
Love how clean it looks....just the way a r32 should look
complete side skirt.
previous owner had tried to make this car look like a N1.
But I wasn't a fan of all the aero parts on the car so removed the bonnet and boot lip and left just the skirts and rear pods.
looks good man, i was very close to getting the skirts and rear pods but i got a picture preview and it changed my mind, but ur one looks good with it , maybe its the photo that i recieved that turned me off..
didn't really wna kit up a gtr tho they look beautiful standard. but im in love with the vspec mudflap looking thing.
I felt it filled out the gap for the 32's and for a GTR you don't really want to go any other type of side skirt other than a N1.
but that's me personally
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
