thanks guys.
18x9.5 +12 Scott. Fit nicely, flush and no scrub. Running RSR's 255/35/R18
265's on the GTC's caused minor scrub when turning tightly at very low speed. embarasing :blush: in car parks.
Could of put 255's on the front of the GTC's but just :wub: the LM GT's.
You are very lucky mate. I also wrote off a gtr and was very very lucky.
I should create a thread for written off gtr's as it can happen to anyone when u have some serious power under the hood - or is this a bad idea to bring up the past which most ppl (including myself) want to move on and forget?
I think it is ok , part of moving forward is being able to look at it and just be thankful we are still here to buy another GT-R :) Mine happened coming home from work on f3 someone crossed onto my side of freeway and i hit them at 110 as it was on bend and no time to react ! Oh and that drivers seat was from the pair i bought from you )
i remember you now - did i drop the seats off at your dads place in chipping norton? hang on, that might have been the buyer for the rear seat!?
man - those seats came out of my black gtr which i wrote off...i think that car was possessed (sorry, in advance)
Yeah they are the seats i got my mate to pick them up for me , i still have passenger one for game console :)
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
