anymore detailed shots of these cars?
Yes please more pics of the top R32.
Sorry fellas, only took the one picture of the Gunmetal one.
I wasn't allowed into the garages, so this is all I've got of the other 32.
What Turbs going on Matty ?
"Hammer Time"
GT3582, .82 rear with a Tial 44mm gate :D
Tilton pedal box in there?
Was it a pain to fit?
Actually, OPW pedal box and tilton resevoir, master cylinders and bias adjuster cable.
As for it being a pain, im a bit undecided IF it was worth the effort. Havent had a really good drive with it yet to be decided
Pedals themselves were too closely spaced, we ended up remounting the accelerator and clutch pedals on the outer edges of their shafts rather than centre
Had to lop the top 1/3 off the accelerator pedal (as it was way too long)
Had to make a way to mount a throttle cable to the pedal (and for now we're using an MX83 Cressida cable as its the right length.....will get a proper one made up later in the year)
Had to make a bracket to mount the brake light switch (and that just reminded me i STILL have to extend the wires to it LOL)
Some ppl say the interior has aged but I don't see it, classic yet simple dash with great seats and the best design steering imo
Thats it ! What more do you need a/c power windows comfortable seats and rb26 to listen too :) OH , and grip like a mother f**ker !
People who bitch about the R32 interior, clearly have an invalid argument.
As clearly it is the least thing to whine about.
If you bought a car to have a 'nice' looking interior, you'd buy a luxury car.
(Not saying the Skyline interior is ugly)
I REALLY wish I could have gotten better pics of the white R32...it was gorgeous. I walked all the way across the road and across two parking lots once I saw it to take a picture. So sad they came out like that.
I personally don't think an r32 can look as good without the rear wing.
My mate who owned DARDVL had set the quickest top speed down conrod straight at bathurst...anyway, at the time he ran it and hit 285kmh with the rear wing fitted. He then decided to remove it to gain a few km and said that he couldn't push it close to 285km due to lack of downforce.
My point - r32gtr not only looks better with the rear wing BUT it also serves a performance purpose :)
+11ty
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
