Would you take Garage Saurus GT-R over a Z tune R34, F40?
Depends on the application...
I believe the Garage Saurus R32 GTR is purely a drag car setup.
Nismo Z-Tune is all-rounder sports / performance circuit car.
Ferrari F40 is a legendary 80's - 90's Super Car.
Thanks for your answer, I would still go for Garage Saurus GT-R, I have seen a white F40 on Speedhunters which does look hot. http://www.speedhunt...40-in-high-res/
That F40 is so nice.
Those brake calipers!
Dspeeds look great with the Projector headlights. Due to the lines in the lense make them look OEM'ish.
Good work for blackening the surrounds.
N1's a different matter. I think the tinted ones look better due to the black in the headlights.
I recall $400ish for Dspeeds from RHD deliverd and about $240 for the tinted from Justjap
f40, then sell to buy z tune, personally, z tune is one of my all time dream cars.
Theres only 1 car I would take over it.
see cars that make you thread in wasteland.
They're just under $450 delivered from RHD at the moment.
I remember with my Kandy Red 32 I paid somewhere between $6-$700 almost 10 years ago.
I guess that's part of the reason they are still quite a rare sight on the roads.
I would prefer smoked D-speeds with the N1 lights because IMO the eBay/Just Jap ones don't look quite right due to not having any lines in the lenses.
I will be giving the bulbs a dusting of silver spray paint so get rid of the orange.
Just get T5 clear and clear globes. Do they sell smoked Dspeed ?, I couldn't find any :(
The one issue I found with Dspeeds is the black lug at the back, always seems one of them breaks off from new even.
Must admit also Justjap (JJR) ones are more solid.
I have a new set of clear Dspeeds but they didn't suit the new N1 headlights :( . (if any one is after a set $440)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
