If you guys ever want a white 32 to come along next time let me know :yes:
When I get back from London I will be joining Sau Vic for sure. Should have done it a long time ago.
Yeah mate for sure, when I get back from the states later this year we should get them all together
Heres another one Marko R1, and wheels are 18x10+18
228 over 3 years
N1 racing was massive back in the 32 days and a whole heap of them went straight to the track and never saw the street.
gee so its quite a bit more than the 34s. though similarly a few of the 34 n1's were sold straight to japanese tuning houses as track only cars
2 asses are better than 1 right ??
did u buy that r32n1 off eBay? I think the plates ring a bell!?
228 over 3 years
so what is the rarest r32gtr? ADMs via nissan aust only released 100...my brothers gtr is 1 of 6. I'll post a pic!
rims are super tough
The gtr in front is mine and behind is my brothers which is a Scuderia gtr. 1 of 6 and his is compliance number 001. Has standard n1 front and rear lip with snorkels, scuderia boot badge, scuderia instrument cluster and scuderia compliance plate as the car came to aust as a low volume import and sold here back in 89, via scuderia showroom in Vic.
This is an old pic taken in 2004.
nah have had it for almost 5yrs.
did buy it off a delaer who had it on ebay, but the plates were put on by me well after
def Aus 32's are the rarest of the mass production 32's.
There's a fair few around the boards and i think in this thread. Other than a Nistune to correct the ecu to Aus fuels and a Trust boost controller to stop boost spikes she's pretty much standard. Oh and has a NISMO exhaust from the period of the car. Thats it. Actually it does have air-con and a radio which are mods for the N1 :)
Here's a couple but probably repeats
2x super neat cars.
gorgeous.
radio and a/c=ruined it.
you'd be surprised how many street versions had them fitted in japan. Yet to see a 32 N1 without a radio and have seen 1 worldwide without the a/c and that one's in canada.
Here's its moment of fame in the Tele a few years back
from factory?
i thought the whole idea was weight saving?
always willing to be corrected with the truth.
so school me boy.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
