hey guys, i had a little accident and went up a gutter backwards........
rain plus corner plus me = :) missed the pole by less than a meter i reckon pooor car :)
soooo ill show pics lol since its the r32 pic thread i suppose,
ooops
Edited by Caza
32line very very nice
Can you please tell me name of those rims :)
How low is the car from centre of wheel cap to guard?
cheers,
they are Lenso GT-05 rims...
How low is the car from centre of wheel cap to guard?? no idea...
why does that measurement matter?
the lowest point of the car is about 120mm
cheers,
Ive got some shocks/springs waiting to fit on which will drop my car to 340mm (from centre to guard) wanted to know if it will be same as your car, as i want a ride height like yours :D
ahh, its approx 320mm from centre cap to guard...thats the front wheel...my front sits slightly lower than the rear
watch the height of ur exhaust if ur lowering ur car...ur exhaust will prolly hang lower than mine...cause i got mine lifted to pass rd worthy...now its clears the ground by 115-120mm
EDIT: also...the rims are 8's all round..with 225 at front 235 at rear. the fronts rub sumtimes in hard cornering...
AND...these lenso rims didnt clear the 4piston calipers at the front, they needed some minor modifying to spin freely without hittin the calipers :D
Edited by 32line
Hi Guys
Been reading and checking out the cars in this thread since it started and im amazed at the quality of cars and pic's that adorn the pages of this forum so thought it was about time I added mine .
first lot of pics is my old black 32 b4 its untimely end
post-7066-1184916328_thumb.jpg post-7066-1184916375_thumb.jpg post-7066-1184916419_thumb.jpg
And the new r32 bought june 06 fully rebuilt and near compleation may 07 post-7066-1184917145_thumb.jpg
post-7066-1184917284_thumb.jpg post-7066-1184917368_thumb.jpg post-7066-1184917441_thumb.jpg post-7066-1184917559_thumb.jpg
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
