my mate will spray it free and ill fit it so a bonus there :D
if that is with the bottom lip its probably not too bad a price, i want the one identical to yours with the holes, any idea of the vin number of a car that came with one standard?
Edited by 2630GTS
Those holes are N1 vents. To get a genuine GTR N1 front bar costs a packet and they are rarer than you can imagine, and Nissan will not sell you one. The genuine vents are worth like $300+ (just for the vents) but few people have real ones. Mock ones can be found starting about $50 on ebay etc.. A genuine GTR fr bar will not have indents for the slots at all so you would have to cut them out... not sumthing you want to get wrong!
There are comapnies that make fakes for like $550 they have indents, so you can pop them out and buy some vents to put in there so thats about $600 before paint and fitment..
im pretty sure it is a nismo option rather than only fitted to n1 32gtr's, they are simply too common on gtr's. im sure many owners could confirm this.
ill give nissan a call tomorrow cheers :D
You could option them from nissan when buying the GTR also, but the vents are called N1 vents. The genuine vents themselves are worth HEAPS. And I promise you Nissan will not be able to help you with them. Mine are fake, 32line's are too, another friend I know had them and they were fake. They are common because a lot of people get the fake ones.
Hey Rekin nice rims I am keen on these from Just Jap, what size and offset are they?
Thanks :thumbsup:
17x8 +30
17x9 +30
I might have some troubles lowering the car as the rears stick out a fair bit. Dont think its an issue with the GTR's but :huh:
Are you sure the guards will need to be flared?
Ive got 19 x 9.5 with 265 rubber on the rear. Apart from the guards being rolled, I certainly dont have them flared..
Got a couple of cool photos ;)
Edited by Yidz
I've got the same wheels, same size and lowered.. so U need to roll and flare the rear guards
Cheers
rolling i can deal with, but not really keen on flarring..
Can you post a pic of a closer look at the flarring?
Also how low is your car from centre to wheel arch?
I think my shocks will drop the height to 340mm and hope i wont need to flare..
Thanks
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
