hey Abu...yeh, alex owned the car a few years bak....
Hey man
Yeah thought it looked familiar! Very nice car man, GTR fronts are awesome :)
.. and abu! the first r32 u posted up (i think origin lab car?) looks sexy as!
Yeah how fkn hot is it!
ORIGIN rear bar and side skirts, with the GTR front bar, lower lip and N1 vents wooooo hot!
I got a video of it somewhere tooo.
Edited by abu
how i get my exhaust to sound like that :nyaanyaa: i have the lamest sounding RB20 ever lol
What sort of exhaust do you have fitted ?
Heres a quick video of my 32, the Fujitsubo Legalis Super R exhaust sounds good without being droney like some can get.
http://www.youtube.com/watch?v=SjBJ8wwBMuY
:worship:
Kakimoto cat back Q_Q soooo quiet, has full 3inch turbo back to cat though. so the right cat back would make it HOT
edit: wat width are your rear tyres ? watched ur other vid with the little bit of smoke. i cant do that in my car lol, never get smoke. dunno if its cos my car is weak cakes or cos it has 255's
They are 265/30/19 Falken FK452 tyres, they are brand new, thats why i only let it rip a little bit, plus that was out the front of my house. LOL.
The Cusco type rs 2 way diff and Exedy heavy duty clutch helps when wanting to smoke up the rears...................
Do you still have the standard clutch ?
well apparently it has an aftermarket clutch (so i was told when i bought it) and people always comment on it when they drive is so i see no reason why it wouldnt be true, was told its brass button, but its not very heavy, just precise and grippy. might be cos my tyres are cheap shit, but if i go round a corner with a bit of speed, not enough to loose grip though, the back end bounces lol.
I've got a Kakimoto Catback & its loud as :wub: Do you still have the silencer in it? :no:
nah man no silencer, very odd that yours is loud, the brand is apparently known for being quiet, unless u have a specifically loud model ?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
