  • 3 weeks later...
It Aint Pretty But she f**king hammers... RB25 in my 32
Oh and I decided to dummy fit the rear wheels... overfenders leave japland in 2 weeks, not long to go now and itll be 100% finished.
Dummied up the flare minus the overfenders obviously
All ghetto'd up with tape just to give a general idea of what she might look like when done, overfenders and finishing should make a big difference but you get the idea :blink:
By the end of the year the goal is to be putting down 600hp at the treads and to have all the cosmetic work finished.
Shit Camera. Ghey Sun. Clean 32.
Yeah very nice 32 man, luv those rims but what is with your camera? my fone takes photos much better than that... i'd be taking it back to the shop asap. heres one of mine (in progress) i took on the fone, getting rims soon then lower it and that will be it for a while before i go broke...
Here's a few photos i took today with a shitty point and shoot camera.
The front bar is off at the moment because of a little driveway accident. (driveway won)
Ive added a few pics of the damage to the front bar, if anyone has done this sort of repair before please pm me as I have never worked with fibreglass before.
Edited by FOG35
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
