most recent pics. i think that wing is coming off again, i get over it, one month on one month off.....
wing has been on for like 2 months, longest ever, only thing that would make me not change the boot again would be, no wing, but LIP... sexy ass!
Wing off for a little while me think, although its good because blocks headlights behind and makes it eaiser to park, holds the boot down when yo pop it too....
Wing off time
and maybe R33 wheels back on...
or you guys like the R32 blackies?
Just had a major makeover to my 1992 R32 GTS-T 25 DET NEO
Put a new kit on it its a genuine Final Konnexion only just come in to aus. Vented hood put on and a tyed up done to my engine bay.
Will be pulling her off the road after xmass geting bigger turbo and alot more work done to it. The car is at 280bhp at the moment and wont to get in to the hi mid 300bhp mark.
Suprised to see 2GU UP cruising, always saw it as a show car..
I hate show cars, but that thing has grown on me.. im really starting to like it.
its more of a street car to me than a show car
i drive it all the time and take it everywhere
if i finish it the way i want to and i stop driving it every weekend then it will be a show car :(
if i finish it the way i want to and i stop driving it every weekend then it will be a show car :)
lol was gonna say. Your probably the only one who actually drives his "in progress" showcar
pretty good on fuel too :(
to finish it the way i want so its an all out show car
veilside widebody, paint again and airbrush, undercarriage, custom fabricated engine bay, tubbed, 12" wide rims at the back.
basically a summernats style build
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
