Brad - I am located in Sydney so not sure how practical it would be to freight it down to Sydney...however if I can't find something in Sydney I will be interested for sure. Will be in touch
Spoolup - Sent u a Pm the other day about the lip...still no reply. So I have emailed u and PM'd u in regards to the reinforcement bar. Look forward to hearing from you asap
Cheers
Pat
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
