Just recently purchased a 97 r33 SII type m skyline, my commodore just went this morning, so im going to pick up the car most likely on wednesday at the latest.
its already got a full HKS exaust, recaro seat.. so i just wanna get a couple of the other things, i do know a couple people that work at autobarn and can get them cheaper, but there still a rip, ill most likely end up getting them from GKTECH cause there very well priced and looks like there very well respected also.
POD - most likely K & N or blitz
BOV
adaptors...
and turbo timer..
PM me if you can offer anything.
Must be melbourne based.
Edited by B-rad33
https://www.sau.com.au/forums/topic/119782-few-things-for-r33-gt25t/
hey brad
just letting you know that 9/10 payments for the coolers are cleared...so if you still wanted in and didnt wanna wait, its looking good :)
also, for the pod, consider an apexi filter....dry element (legal in vic) and very low maintenance...also 1 of the best flowing etc...
See here:
http://www.mkiv.com/techarticles/filters_test/2/index.html
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
